aruba5er
May 18, 2014Explorer
12700# gross and you should have 15% of that weight on the pin I believe so 10800# are on four tires.3500x4=14000# Kinda appears that you have a margin of 2 tons with the ST's or would have TON WITH THE LT'S. If possible I would weigh each tire to get a more accurate idea of what you have. 65 mph? most people do not know that. You could read it on the side of the tire BUT? I, and most people I know do not drive faster than that. No bigge. I switched to LT's and I wonder the stress on the bearings when making sharp turns as the tires do not give like the old St's. When I replace these present tires I;m going back to ST's I know the ride got stiffer and can feel it in the wheel.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
