wandering1
May 18, 2014Explorer
If my rig has a GVWV of 12,700 why are there only 6k axles?
Because that is all you need. Subtract the pin weight from the GVWR.
Would I be over stressing LT tires with the weight above?
It depends entirely on the weight capacity of the tire. Read the sidewall.
Also concerned with what I have read about 65 mph and overheating on ST's. ST or LT, do not run the tires faster than the max speed on the sidewall. Higher speeds than what the tire is rated for will cause the tire to overheat which will damage the tire.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
