CampingN_C_'s avatar
CampingN_C_
Can't fill tank at pump.
So I've tried several times to fill up at the store vs. cans and it will barely take in fuel from the pump at all, if it does I have to pump it as slow as possible and it takes for ever.
The vent tube at the top of the tank looks plenty large enough and I can't see any obstructions.
Any ideas ?
  • NMDriver2 wrote:
    There is a wasp that like to nest in tubes. Blowing into the tube could send the nest down into the tank. Remove tube at tank and blow out.
    Agree with this...have had this happen more than once on my fresh water overflow line.
  • Get a bore scope for your phone and look to see what's messed up then fix.
  • There is a wasp that like to nest in tubes. Blowing into the tube could send the nest down into the tank. Remove tube at tank and blow out.
  • It sure sounds like a vent tube problem, try blowing backwards on vent tube. Could be plugged in lower part.
