jimcatinmi's avatar
jimcatinmi
Can't find my water pump
We have an 2015 keystone alpine 3010re and I am trying to find the water pump I have taken off the 3 panels 2 under the kitchen sink and 1 in the bathroom and can't find it. I ran the pump and can hear it but I am afraid to run it for too long as I don't want to burn up the pump. It is new to us and we are using it for the first time. I filled the fresh water holding tank and but the water heater bypass to off I have the selector to normal and I can hear the pump but it is pumping water to the faucets. Any help will be greatly appreciated
  • I would be very surprised if you could hurt the pump by running it. I accidently left mine running in our last 5er for a day and a half before I discovered it. It happened at home and I had no water in the tank. I replaced the pump, and now I still use that pump to transfer water from jugs to my fresh water tank.
  • I agree the post is a little confusing. Just remember the pump has to fill up the water heater before you will have much pressure to the faucets.
    the pump is usually close to the back of the water heater.
  • Most pumps can be run dry for a while, with no fear of damage/burnout. It will be near the fresh water tank, and may be behind a panel best accessed from the pass through. Mine has a square cover, over a hole in the panel in pass through/basement.
    Your post is a bit unclear, are you saying it is pumping water to the faucets? If it is, what is wrong, and what are you asking?
    Jerry
  • I would look in your outside hatch, and I bet if you look around the wet bay theres likely a false panel between the nylon wet bay and the pump/hot water tank and valves. If its running then either your hw tank is still filling or you have the valves set wrong and its sucking air possibly through the winterizing tube.
