d-mac1
Sep 12, 2016Explorer
So...is it working by now? Hopefully!!
Just wanted to say, you don't need to completely FILL the fresh water tank to be able to use water from it. You do need some water in it though...obviously. So you turn the valve to Fill until you've got enough in it, then turn off the flow into the tank, disconnect the hose and turn the valvue back to Use Tank or City Water. THEN go turn on power to the water pump.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
