N-TroubleExplorerJul 09, 2013Can't get grease into shackle boltsI was going around doing my annual greasing of my shackle bolts on my 2004 Weekend Warrior and found that a couple of the bolts I was unable to pump grease into the zerks. I assumed the zerks were st...Show More
shawnct450rExplorerJul 09, 2013Ditto on jacking the trailer up, behind the axles using the frame (not the axles). This should allow flow.
Related ContentGrease gun/ grease recommendationsshackle replaceshacklesRemoving seized shackle bolts?Equalizer Shackles Hitting Frame
