time2roll
Sep 02, 2013Nomad
driveandfish wrote:
Not to hijack this but I am still having the same problem. I have gotten grease in all the bolts except one. I have tried with it jacked up and on the ground and many positions in between. One bolt will not take grease. This is the first time I have greased these. I am not sure what the previous owner did. Can I pull the zirk and clean the bore somehow?
Did you replace the zerk?
You will probably need to remove the bolt to inspect. Install the hole horizontal and I recommend adding a small chamfer to the hole with a round file before you reassemble.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 24, 2026
