Pipeman wrote:
Drive it like a tractor trailer combo. Swing wide when making right turns when traffic allows or wait until traffic clears to turn.Same when turning left. ...
Bad advice. Do that on a drivers test and you will fail. The following is from the IL CDL Study Guide ( the diagrams did not come through, but they show staying your lane and going deeper into the intersection before turning right, even if you enter the lane for oncoming traffic from the right.):
"Space for Turns
The space around a truck or bus is important in turns. Because of wide turning and off-tracking, large vehicles can hit other vehicles or objects during turns.
Right Turns – Following are rules to help prevent right-turn crashes:
• Turn slowly to give yourself and others more time to avoid
problems.
• If you are driving a truck or bus that cannot make the right turn without swinging into another lane, turn wide as you complete the turn, as shown in Figure 2-11. Keep the rear of your vehicle close to the curb. This will stop other drivers from passing you on the right.
• Do not turn wide to the left as you start the turn, as shown in Figure 2-12. A following driver may think you are turning left and try to pass you on the right. You may crash into the other vehicle as you complete your turn.
• If you must cross into the oncoming lane to make a turn, watch out for vehicles coming toward you. Give them room to go by or to stop. However, do not back up for them, because you might hit someone behind you."
