therink
May 19, 2013Explorer
Sounds like brake light hot wire is connected to the trlr brake pin on the connector. Do you have brake lights?
An easy way to test it is used a voltage meters and check each pin as the brakes are applied. Should be brake light hot when brakes applied, aux hot(all the time) and trlr brake hot when brakes applied (voltage will vary depending on gain set at controller. 3 hot total. If running lights are on then 4 hot total.
Steve
Steve
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
