- BC__CANUCKExplorerThanks to all. I will make an appointment to have it looked at.
- Get a Genturi. Ours did same thing at times. Got a Genturi & never had a problem since
More reading about it - steadfastrockExplorerCheck to see if your access door on the generator is properly sealed. I had our propane detector alarm when I didn't properly close the access door on our Onan 5500 propane generator. The cooling fan was sucking in the exhaust and blowing it out underneath the coach. (It doesn't cool well that way either).
- roam1ExplorerGo buy another CO alarm and see if it still does it.
I had a pesky one that always went off and when I bought a replacement, the problem went away.
And I'm still posting years later! - broark01Explorer IIWind is a consideration, also if you have the windows open or closed and the vent fans going. I would recommend that if you are running a generator that you close the windows in the 5th that are closest to the generator including the door.
- Fresno_Tundra_DExplorer
Allworth wrote:
Carbon Dioxide (CO2) makes bubbles.
Carbon Monoxide (CO) makes dead people.
Both of these gases can kill people but carbon monoxide(CO) does it much quicker! - AllworthExplorer IICarbon Dioxide (CO2) makes bubbles.
Carbon Monoxide (CO) makes dead people. - Swamp_ManExplorerCo is nothing to play with. Take the rig in and have it examined/repaired as need. Search death by generator and see all the people who have done very stupid things after hurricanes with generators. I have seen several while I was in LE.
- joelcNomadDon't fool with CO2. It is a killer. You either have a leak, faulty unit, low battery. Either get it checked by a authorized rep or replace it. Also, check your compartment for any areas where you could have intrusion to the living quarters. I believe technicians might have a meter for this.
DON'T LET IT SIT. GET IT FIXED IF YOU ENJOY CAMPING IN THE FUTURE. - RoyBExplorer III can set mine off just by pointing my tailgate mounted 2KW Honda generator at my trailer. I found this out by accident one time and I now am very conscious where the generator is pointed to. Alot of campers are pretty close to each other in the camp grounds so I make sure the generator exhaust is not pointing at any of them when running...
I also have trouble resetting my alarms once they get set off. I guess it takes a few minutes for the fumes to totally escape from the sensors.
Another thing I do in my OFF-ROAD camper is I have two sets of sensors setup... If both are going off I am pretty sure it is an actual emergency instead of the seemly false alarms alot of these sensors seem to do.
Be thankful for the alarm going off...
Roy Ken
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
