Francesca_Knowl
Jan 09, 2013Explorer
tulegit wrote:Francesca Knowles wrote:
Wow-
That generator is much like the one that killed those bikers last year when they had it running next to the trailer. In their case, a hatch door was ajar. It may be that running it in the bed while hitched is too close
Also:
Don't overlook the possibility that your furnace fan, which draws OUTSIDE AIR to operate, may well be sucking genny fumes into the trailer.
If the generator is too close how do onboard generators get by without setting off the alarm?
Do people with onboard generators have issue with the furnace sucking in the outside CO air?
I hope that most onboard generators are properly vented/stacked to avoid such things...portables are a completely different animal.
It's a plain fact that nearly all carbon monoxide poisonings are related to gasoline/diesel engines, and inappropriate placement/use of portable generators is/are an important contributor to the problem.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
