JIMNLIN
Jul 16, 2014Explorer III
Our 11200 lb 5th wheel RV usually sits from late Oct through March. The tires sit on 2x8"x36" long in the RV shed.
I slide my 12 ton stubby hyd jack under the end of each axle tube and rotate the tires 30 degrees or so a couple of times a winter.
I use LT tires on all of my trailers including the RV. I run the RV tires usually around 7 years on average and 45k-55k miles. LTs on my equipment and flatbed trailers 8+ years as they sit empty , out of the sun, much of the time anymore.
Years ago when the biggest camping trailer (RV) was in the 22'-24' range ,most were less than 20', many folks jacked the trailer off the tires for winter storage. Todays trailers are much larger/heavier = much more dangerous for the average Joe to do the job and do it safely.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
