4hapyMcDs's avatar
4hapyMcDs
cargo carrier on bumper
We just purchased a bigger generator for our 5th 3000 powerhouse, after getting it home and ready for action we discovered my measurements were a little off and it wont fit in the front storage where we carried our 2000 watt. Now we are torn between keeping it in bed of truck which will cause headaches for use of it or buy a cargo carrier and attaching it to the hitch sleeve we purchased on the pumper of our greystone...Does anyone know if the weight on the 5th wheel bumper will accommodate 125lbs...
  • just built a bumper off the frame of the 5er and put my 3000 yamaha on it and a couple other items works great.
  • Your best bet is to have a 2 inch receiver hitch installed on the trailer. Remember for every 1 lb attached to trailer bumper that was in the front basement will remove about 1.5 lbs from the pin weight.
  • You will find quite few threads here dealing with carrying things on the bumper. They are only designed to carry the sewer hose. Some bumpers are stronger than others but I think 125lb is pushing it. Some have bypassed the bumper and had an actual frame-mounted hitch welded on. That, to me, would seem the most prudent approach.
    Alternately, if you don't carry the sewer hose in the bumper, have it cut off and replaced with something that will do the job.
    Next item: if you're going to hang 125lb PLUS the carrier and beefed up bumper/hitch, etc. on the back, you'll have to transfer a lot of interior weight forward to keep the pin weight right.
    Stu
    PS If you bought a 3500 / 4000 Watt generator that is not red or blue, then you'll want to dismount it to run it.
  • I did that on my last trailer. What you have to watch out for is the flexing of the bumper while you are going down the road. I attached an eye-bolt to the back of the trailer and then used a cable and a turnbuckle to cinch the bumper mounted cargo tray tight. In 5 years of use I had no problems and never got any weld cracks.
    Good Luck!
