Huntindog
Mar 29, 2021Explorer
wopachop wrote:I have done a lot of automotive AC work. As result, I have an awesome O ring collection.:BHuntindog wrote:I hear you. Typing this inside a toyhauler sitting in the garage/dining area. Gas cans can seal really good. If yours dont you can buy the big black oring for the main cap. If the little vent doesnt seal you can probably buy that as well. I recommend buying the green nitrile oring set from harbor freight. That set has saved me so many times. I fixed a darn leaking kureig coffee machine once with them. There is a size that works perfect for the gas can vent.wopachop wrote:The toys come out at camp. The garage becomes a dining/sleeping area
Only issue will be smelling gas if you need to sleep in the toyhauler with toys in it.
The toys actually have a vent that can fail. Its supposed to allow air into the gas tank, but not let fumes out. Ive had to sleep in my trailer with toys in the garage and its not fun. Those fumes are no good. My trailer has a front bedroom and even with the doors shut and windows open i will taste gasoline in my mouth for days.
Point being gas cans should seal 100%. Storing them inside your toyhauler is no big deal if done safely. Ive read the plastic itself is pourous. So its horrible for long term storage. But traveling with a common 5g gas can inside the toyhauler is very common.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
