dieseltruckdriv
Feb 06, 2023Explorer II
dieseltruckdriver wrote:halcareric wrote:You are off almost 1,000 lbs on your pin weight. It looks like a simple math error. It's easy to do.
Hello all. First time weighing our rig after almost a year full time
2022 Ford F-350 Crew Cab 8' bed Dully Diesel 2x4 XLT
2022 Durango Gold 391RKF 42.5 foot 5th Wheel
Full tank of fuel (48 gallons). NO fresh water, grey tanks empty, black tank had maybe 15 gallons. Fully loaded like we normally do.
Truck had my wife and I, plus 3 dogs in crates in back seat. Portable Generator, and portable waste tank with 3 dog X-pens in bed. 2 bikes and an aluminum ladder on back of trailer.
CAT Scale numbers. Truck and Trailer
Steer Axle: 4,800
Drive Axle: 7,260
Trailer Axles: 13,400
Total GVW: 25,460
CAT Scale numbers: Truck ONLY
Steer Axle: 4,760 (diff of 40 lbs)
Drive Axle: 3,960 (diff of 3,300 lbs)
Gross: 8,720
If I did this correctly, this is my trailer gross and pin weight. Pin takes some of the weight off the trailer axles.
GROSS: 25,460 - 8,720 = 16,740 for trailer gross weight
Gross of Trailer 16,740
Trailer Axles only - 13,400
Pin weight = 2,340
Rear pickup axle weight loaded minus empty.
Also it looks like you could have your pin a little farther forward, you are taking weight off the front axle. Ideally it wouldn't change, or add about what you are taking off it.
About Fifth Wheel Group
