Hammerboy's avatar
Hammerboy
Cat Scale Results
For those of you who are into numbers I went to the Cat scales with our rig finally for the first time with this truck and trailer combo.
I went to the scale with just my truck and then about an hour or so later with our fifth when we were on our way to campground for the weekend. These are the results that I pulled from the tickets with the truck and fifth fully loaded with wife, me, and all our normal gear with the exception of our aluminum bikes that normally go in the back seat of the truck: Note my wife (140#) was not along for the ride on the solo run.
- My truck empty but with full tank diesel, B&W Patriot slider (221#), me (215#) is 8100#
- Factory dry weight of fifth is 9020# and pin of 1510# with a GVWR of 11,900#
- Loaded fifth weight of 10,700# and a pin of 2040# putting it 1200# under it's GVWR.
- My truck is 280# over its weight rating of 10,000# although I'm not concerned as I am under my axle and tire ratings
- Drive axle loaded with fifth 5540#, rated for 6200# and tire rating of 3525# or 7050# total
- Steer axle under by 420# (5200# rating)
My truck landed about where I thought it would but I was surprised at how much cargo ## that we have, I would have guessed around 1000# and I didn't carry any water with us either. I'm just glad we have a healthy cargo capacity on our fifth.
Although I feel very comfortable towing with it and am satisfied with what Cat scale results were, my next truck if it ends up a diesel again will be a SRW 350/3500 even though it is highly unlikely we will ever move on to something bigger due to campground site sizes.
Dan
  • So your truck has 1,900 pounds of payload and with the wife on board, you're overloaded by over 400 pounds--over 20% of your payload capacity.
    Why is your truck itself so heavy? Can you move load to the trailer? Mine weighs 7,100. I know newer trucks are heavier, but where did they put the extra thousand pounds?
