Bamaman11
Jul 30, 2014Explorer
There is a lot of information online on generators. See http://www.electricgeneratorsdirect.com/power/rv-generators.html
You do best to buy no more generator than the power you'll need. Many RVers will use two 2000 watt generators hooked together. Or one 3000-3500 watt generator. Inverter generators vary rpm's according to the load, and they're the quiet generators. Inverter generators' power is also cleaner--for electronics.
Honda and Yamaha stick out at tops in RV use. Champion sticks out as the best of the cheaper generators. They have a 3100 watt model inverter generator that's less than 1/2 the price of the EU2000 Honda--and it's very nice.
You might want to read about home generators online. You've got to install a second circuit breaker box, and pick out a few circuits to run via generator. There have been many utility workers electrocuted by generators that are not installed properly.
Most homeowners will have all refrigerator/freezers, kitchen, living space, bedrooms and the furnace on a generator. You don't have to use a 20K watt generator--and most will use 5500 watts or so.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 14, 2026
