MainerBob's avatar
MainerBob
Charge Line
A recent message said that while I am on the road my truck is actually not doing very much charging of the batteries in my 5'er. The trailer carries two group 27 deep cycle batteries. The poster said this is due to the small gauge of the charging wire from the alternator back to the plug.
Is there anything I can do to improve this situation short of buying a generator? My thinking is that if I spend 2-3 days boondocking and then get back on the road, after a few hundred miles of towing I will still have mostly depleted batteries unless I stop somewhere I can hook up.
Have I got this right? Any thoughts?
MainerBob
  • A lot of us have gone solar, but that gets expensive.
  • Yes power is lost over distance and guage of wire. You will need a diode so you don't get feedback from the 5er. You need to have most shut off in 5er so you don't draw from it's house batteries.
  • MainerBob wrote:
    A recent message said that while I am on the road my truck is actually not doing very much charging of the batteries...
    MainerBob
    Hmmm,
    Our experience has been the batteries recover and charge quite well when connected the truck.
    The fuse for the charge circuit is 20 amp in our RAM so I've always assumed a hefty amount of power is pumped to the batteries.
  • I have heard of people running a 8 gauge wire, thru a relay, to the battery. To replace the smaller wire. The relay would be activated with a line to the ignition to cut off power when the truck is shut down.
    BK
