will2020ExplorerJan 12, 2014Chassis boltsHi, Does anyone know the correct name of the bolts with the teeth in the back of the head that are used to fix the 5th wheel brackets to the vehicle chassis? Any help or links to replacements appr...Show More
will2020ExplorerJan 12, 2014Thanks Any idea on what you call the wire you thread onto the bolt then feed it through the chassis to the fixing point and pull the bolt through?
Related ContentRemoving seized shackle bolts?Coach to chassis boltschassis battery charge ?Freightliner chassisChassis Ear
