will2020
Jan 12, 2014Explorer
Chassis bolts
Hi, Does anyone know the correct name of the bolts with the teeth in the back of the head that are used to fix the 5th wheel brackets to the vehicle chassis? Any help or links to replacements appr...
will2020 wrote:
Thanks
Any idea on what you call the wire you thread onto the bolt then feed it through the chassis to the fixing point and pull the bolt through?
