Hi, Does anyone know the correct name of the bolts with the teeth in the back of the head that are used to fix the 5th wheel brackets to the vehicle chassis? Any help or links to replacements appr...
I believe the poster is referring to a wheel stud type bolt. Round head with splines under head to grip frame without access to inside frame rail to hold with wrench. Something like This Maybe also called Knurled bolt. Best bet is to go to automotive and match up if you have one for show and tell. Randu
