MFL
Jul 29, 2020Nomad II
The touch method is better than not checking, but a temp gun more accurate. Yes, the sun side will run a little hotter, maybe 10-20 degrees. Lots of variables, including over tightened bearing, or brakes not all adjusted the same. The main thing is uniformity being reasonably close on all hubs. One 50 degrees or more warmer indicated a problem, that needs checking.
btw, the term technician may not describe every guy, with a wrench in his hand. :)
Jerry
Jerry
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
