Thermoguy
Aug 01, 2020Explorer II
2oldman wrote:memtb wrote:It's not the actual temperature they're after when using their hands, it's whether the warmth feels all about the same.
I’d be very surprised if the majority of people could get within 20 degrees of the actual temperature when using there hand.
Since I have one it's hard to argue the benefits one might argue by not having one. But, mine takes pictures and allows you to see where the heat is. I can tell you from experience, that the tire heat is on the tread, but the bearing heat is not on an area you can touch from the outside of the tire or hub, it's on the inside. You can't touch that area and some bearings can be over 200 degrees. Good luck with your hand. Also, heat is relative, so you are looking for all to be about the same, not an absolute number. In addition, a failed brake has no heat. You're not going to feel that with your hand.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
