Texas_Two_Stepp
10 years agoExplorer
Chevy integrated brake system
I have a 2015 Duramax dually and pull a 16k fifth wheel. I am having tire issues on the 2013 fifth wheel which have been attributed by professionals to brake issues. I am getting flat areas straight across the tread on 17.5" Michelin XTA tires on the front axle only. The brakes are disc elec/hydraulic and made by Dexter. The last shop I was in couldn't find anything wrong and called Dexter who attributed the problem to too aggressive a setting on my ibc. I now have it set at 2.5 which in my opinion is too low. I have checked the axle weights etc and am slightly nose high on the rig although it is in the lowest setting on the hitch, pin box and spring hangers. Has anyone had similar problems? These tires are $400. each and I just replaced my second one after only 5k. I am concerned that it might be a ibc issue
