Busdriver wrote:
Had a tire go bad in clinton tn. The only tires I could find was Hy-Line.can only hope I got a good set.
Maybe the tires you bought were Hi-Run?
Given that you have a 2004 30' Sunnybrook trailer, chances are your axles are 5200 or 6K. If it has 15" tires and rims then upgrading to 16" rims is a very good move.
I would also suggest that if you do not want more tire problems in look into installing 16" Michelin XPS Ribs or Bridgestone Duravis R250's all steel ply tires. My third choose is a true commercial duty rated poly carcass tire in the BS Duravis R500HD. The R500HD has a two ply poly carcass where most others have a single ply poly carcass.
It is sort of like putting tire problems behind you and not looking back!!! Chris
