Coach-man
Oct 11, 2014Explorer
Check your vehicles weight/towing capacities! The FW pin weight will be around 20% of its weight, loaded weight, what you will be carrying when camping. You will also need to weigh your vehicle with the passengers and gear you will have thenadd 200 LBS. For the hitch. That should give you a ballpark of where to start looking. I fell into the same trap as you did, I purchased my truck first, then went looking for FW. You might have to pass on some just because of the weight! Good luck!
About Fifth Wheel Group
