Old-Biscuit
Feb 14, 2016Explorer III
Happy Prospector wrote:
Hey Dave, is that check valve that you installed, is it spring operated or worked by gravity?
It is spring loaded......intended use is for RV water heaters
Typically used in HOT outlet to stop backflow into WH bypassed (winterized).
Brass nipple with plastic plunger/spring/o-ring (same design as city water inlet and black tank flush connection check valves)
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
