- DHCamperExplorer
cpaulsen wrote:
Same here...sprayer with bleach and Dawn dish soap....spray on underneath...roll up for about 20-30 minutes....unroll and rinse off.
This is what Dometic recommends in the manual:
Mildew does not form on the fabric itself, but on the accumulated dust, dirt and grime. Periodically clean vinyl or woven acrylic fabric using a mixture of 1/4 cup of dish soap and 1/4 cup of bleach mixed with 5 gallons of warm water. Liberally slosh the mixture on the top of the fabric and roll the awning up for 5 minutes. This will apply the mixture to the bottom as well. Roll it back out and hose off with fresh water. Repeat if necessary.
Works great! - ACZLExplorer
DutchmenSport wrote:
Nah-uh! Use Mr. Clean Magic Eraser.
Then come do my awning. - cpaulsenExplorer IISame here...sprayer with bleach and Dawn dish soap....spray on underneath...roll up for about 20-30 minutes....unroll and rinse off.
- 0rionExplorerthere's 2 things that I can't wait until my boy is old enough to do.....mow the grass and clean the awning.
- Old-BiscuitExplorer III
How do you get it to spray on?
Much rather do the spray/roll up/drink a beverage/unroll & rinse method - ScottGNomad
twins89 wrote:
How to clean awning:
Lowes: One gallon pump sprayer of Tilex mold and mildew cleaner
Extend awning completely.
Spray 2-3 beginning at the roller edge on top and underside of awning, roll up to where you have sprayed
Continue to spray next 3 feet or so, roll up that much more
Finish spraying roll up awning completely
Wait 20 to 30 min.
Unroll, brush lightly on underside
Rinse thoroughly.
Results: Clean, bright awning
I've tried many different products and methods but this is the one that works. No hard work or scrubbing. The spots and stains just vanish. - DutchmenSportExplorerNah-uh! Use Mr. Clean Magic Eraser.
- twins89ExplorerHow to clean awning:
Wait 20 to 30 min.
Rinse thoroughly.
Results: Clean, bright awning - PwrRamExplorerOutdoor bleach works wonders cleaning the awning. spray the awning to wet it spray with bleach brush and hose off. looks like new
- Ka_RonExplorerSounds like you just cleaned the awning??
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
