Sammieb's avatar
Sammieb
Clearance for kayaks on my tow vehicle
I have a ford f 350 crew cab 8 foot bed I am putting kayaks on my tow vehicle. I am towing a 35 foot loredo fifth wheel not using a slide hitch I'm not sure how much room I need to leave between the end of t e kayaks and the hitch. If anyone could give me any advice I would appreciate thank you.
  • Need 3 measurements.
    Back of the cab to the king pin.
    King pin to the nose of the trailer including which side of the king pin its on
    Width of the kayaks
    A pic from the side would help
  • I carry two kayaks on my CC LB. I lay them on edge facing each other. Makes them narrower. They hang out past the cab about 1'. I've turned some pretty sharp corners and never hit them.
  • When I carry one kayak I put it in the center of the truck, about 8" off the front of the 5er. The 5er will pivot around it and I don't have to worry about it hitting.
    When carrying 2 boats I will load them vertically, as close to center as I can get them and can still load them about 12 - 18 inches from the front of the 5er's front cap.
    I have some pics somewhere, if I can find them I will post them.
  • RoyB's avatar
    RoyB
    Explorer III
    I wouldn't go much past the rear window of the truck roof. You will need to account for hard turns with the 5th wheel...
    This GOOGLE PHOTO shows about as far as I would install the KAYAKs. This will most likely require you to have a support frame coming up from the front truck bumper...
    Photos from GOOGLE IMAGES
    Roy Ken
  • Since 5ers will hit the cab of a truck with a 6'8" bed, in a tight turn, I would think that 1'4" behind the cab of a truck with an 8' bed would be as close as I would want to get. 1'6" behind the cab would be pushing it. One kayak in the center or stacked kayaks in the center could probably extend a little further.
