sonofcy's avatar
sonofcy
Clearance over bed rails enough for a toolbox
How much clearance over bed rails does a hitch with 14.5" to 16.5" of vertical adjustment give me? It is the Reese 27.5K that Ford supplies on the F450. 5er is a Keystone Montana. I have no way of checking since I am many hours away from dealer and neither truck nor RV are delivered yet.
The problem is I may not be able to buy it after I get the rig due to time constraints and remote location.
  • On my Dodge I put a Roll and lock cover on. I put a divider in the box in front of the hitch. I keep all my tools up there and the cover locks in that position. When I am not pulling the trailer I can roll it all the way closed. If I want to haul plywood or a bit of lumber I can do it on top of the cover and leave the hitch in. I got rid of the storage box altogether. It is another option.
  • I'm thinking the toolbox would only present a possible problem when turned fairly sharply on uneven terrain at the same time, which probably is an unlikely occurrence. That said, I have an approx 6 1/2 ft bed and my automatic slider sure has paid off. On the other hand, where I pull into my driveway and also when I pull into the backyard, there are elevation changes and my bed and camper almost meet. It's kind of tenuous every time and certainly if I had a toolbox it would be hitting because there is some fairly tight turning involved, but my situation is a little unique.
  • RCMAN46 wrote:
    This is the box I use.
    I have found the 6 inch trailer clearance is mostly needed at the rear of the truck bed. As you get closer to the cab not as much clearance is needed.
    I like this box as it does not go to the floor of the bed. This allows the ability to carry a full sheet of plywood.
