sonofcy's avatar
sonofcy
Clearance over bed rails enough for a toolbox
How much clearance over bed rails does a hitch with 14.5" to 16.5" of vertical adjustment give me? It is the Reese 27.5K that Ford supplies on the F450. 5er is a Keystone Montana. I have no way of checking since I am many hours away from dealer and neither truck nor RV are delivered yet.
The problem is I may not be able to buy it after I get the rig due to time constraints and remote location.
  • One problem I encountered, I didn't have a good view of the hitch with an across the rails box.
  • Your tool box should be in front of your hitch, and unless you plan on turns of greater than 90 degrees you should not have any problems. Clerence to top of bed rail should be 4" to 6" just in case you are backing over uneven terrain! Good luck.
  • How about, what toolboxes are you guys using on your Keystone Montanas or F450s? Btw, are both of those going to be new? In any case, congrats!
