pa traveler wrote:
I would call roto rooter ,and have it done . If its really bad ,I would want it totally cleaned out,they can check with a camera.If it is an easy fix then I would do it myself. If you just bought it ,and found it got clogged rather easily,then it may have rock hard crud built up. But if it has been working for a long time,and this is something new and recent,then using a wand or power flushing tool should do it. I would want it fixed right ,so to prevent a problem next week at some campgroung again.
Well, last night after I said it was emptied, I went back in there about 2 hours later and it was full again. Not all the way up like it was. In fact, it's draining
some now. It's still not draining like it's supposed to. There's got to be something causing it to do that.
1. We emptied, drained fine.
2. 2 hours later went back, used the bathroom, backed up (but not all the way to the bowl)
3. Was drained down about 10 minutes later.
4. After we woke up and used the restroom, same issue with it not draining all of the way. Seems to be just backing up into the pipe.
So, hell idk. If we don't get it fixed, I'm going to just call a freaking plumber. I'm tired of messing with it. And I know my poor bf is tired of it. If it is a hard clump of poo and tp, I mean what other way would we get it out if not by a plumber?
