fidhleir wrote:
For those that do close it, how much pressure does it take? Is it just a tap at the right spot or does it require some amount of force?
Standing in the back of my truck behind the hitch with the hitch jaw open and the handle in the unlocked position... I pull the handle out slightly to relieve pressure on the locking assembly and gently pull back on the locking activation lever (same lever the pin box pin activates when you back in to hitch)
The lever pulls back effortlessly this way,a bungee cord "S" hook works well as does a welding rod with the end bent in a hook position.I then slowly let the handle return to the locked position.
