MFL wrote:
I think the OP means that the slides are closed with the noodles in place. If this is the case, I would make the long drive to close the slides without restriction, to avoid possible damage from leaks, bugs, or rodents.
A charged battery will operate the slides, or take good jumper cables to jump from vehicle to trailer battery if needed.
Jerry
X2
Do you have a true battery disconnect switch?? If so and your battery is in decent shape, it will run the slides in and out several times.
Otherwise parasitic draws will run it down in a couple weeks.
