- dickensExplorerthanks so much everybody!!..very appreciative!!..I only ant a washer..not combo..have clothes thing at back we all made to hang off ladder..
- Cummins12V98Explorer IIIMy RV entry door is 27.5" in the clear. I removed the Chinese Made Whirlpool that came with the RV and replaced with a BOSCH 500 series apartment size washer that is 220V. It is AWESOME been using for two years full time. The whirlpool simply would not eject the water on final rinse all the time.
The US Made Whirlpool 220V dryer has been great with 3 years full time use.
- 2oldmanExplorer II
DownTheAvenue wrote:
Yep, that's about it.dickens wrote:
One that fits through the door and into the space made for it in the RV.
what model clothes washer Whirlpool will work in 5th wheel - rbcampingExplorerAre you looking for a whirlpool washer dryer stacked or only a washer? The stacked units are usually to tall.
- DownTheAvenueExplorer
One that fits through the door and into the space made for it in the RV. - 3_dog_nightsExplorerI bought a Danby from Walmart for about $450 used it for 6 years till I traded in the unit. Had an 11 gal tub. Would spin clothes out to damp, then would hang around camper at night, dry in the morning. Worked well. Highly recommend.
- djousmaExplorerI have stackable Whirlpool washer and dryer in my Cardinal, and they are apartment sized. I prefer the separate units vs the all-in-1 splendide. If buying separate, make sure the dryer is 120V, not 220V as most RV's do not have 220V available.
- donn0128Explorer II
dickens wrote:
have an opportunity to buy whirlpool front loader slightly used
Unless its an aprtment size,how will you get in the door? RV doors are generally less than 24 inches wide. - donn0128Explorer IIYou need a small apartment size 120VAC. Splendid is the most common combo unit sole and used in RVs. Their small size makes them ideal for many folks. Be aware, unless your RV is prepped for a washer dryer your going to be oit of luck.
- dickensExplorerhave an opportunity to buy whirlpool front loader slightly used
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
