pothiemg's avatar
pothiemg
Coachman 355 RLTS Fresh Water Drain and Water Heater Bypass
First post on an RV Forum.
Just got a 2012 Coachman 355 RLTS, we had a 2005 toy hauler before. I cannot locate the fresh water drain valves or the water heater bypass. These are not mentioned in the owners manual, the online videos reference a low point drain valve. I have opened every door and cabinet and cannot locate these. Any help is greatly appreciated.
  • hi the bypasass for hot weater heater. lrft side door of coach and behide the wooden wall on rite hand side take the srews outof the wall and remove the wall and u will see hot water heater and the bypass valve.we have a 2010 345 sa brookstove .hope this helps
  • remdog*1 wrote:
    Your water drains probably underneath, 1 white, 1 red for hot side. My hot water heater bypass is right on back of hot water heater.
    I agree, though the cold water might be blue, like ours.
    If you still cannot find them, you might want to check out:
    Coachmen forum
    for others that might have your trailer.
  • Your water drains probably underneath, 1 white, 1 red for hot side. My hot water heater bypass is right on back of hot water heater.
  • The drains are probably under the trailer somewhere near the perimeter.
    Water heater bypass? My last trailer it was hidden under the kitchen sink.
