Gebrown's avatar
Gebrown
Coachmen vs Hyper Lite?
We've narrowed it down to two, the Cachmen 301bdls or the Hyper Lite 27 HFS. They both have their pros and cons. I like the Hyper Lite mostly because its lighter but my wife likes the Coachmen.
She likes the sliding door to the garage area. When we travel we'll be taking our 5 small dogs, so the plan is to leave them in the garage area while we're out so having a garage we can close a door to is at the top of our list.
The Coachmn seems more luxury while the HL seems more outdoor.
So, family specs, 2 adults, 2kids, 5 small dogs, say 3-5 trips per year, mostly southern states, mostly summer trips.
Tow vehicle, 2008 Ram 1500, 5.7L, 3.92 gears, tow pkg. however, it has 35" tires with a 6" lift.
I'm also going to put a campershell on it so the dogs will have a place to ride.
Possibly taking along a 700lb 4 wheeler, not all the time but occasionally.
Does or has anyone had one or both these models? How do you like it? Any areas of concern?
  • Besides the aforementioned TH's what would y'all recommend? For us it has to have a door we can shut the garage. My wife likes the sliding door on the Coahmen, any other TH's have a sliding door inside?
    I ask y'all because I've looked and looked and that's the only one I can find.
  • Steve76eb wrote:
    Bumpyroad wrote:
    well the Coachmen has a rubber roof so I wouldn't want it myself.
    bumpy
    So you are saying the Hyper Lite doesn't have a rubber roof and that is the one you would choose?
    no, I couldn't quickly find out what type of roof hyper lite uses. those web ads, etc., don't seem to give a whole lot of information. just don't like care, upkeep, and feeding of EPDM roofs now that other materials are available.
    bumpy
  • they both have rubber roofs....
    IMO coachman all the way... forest rivers are junk........
    Plus the coachman's got
    heated and enclosed underbelly's...a 90" raised cargo interior roof line...ducted a/c...55 amp converter....Beavertail Ramp Transition... helmet storage.....Full Walk-on, Crowned, Aluminum Reinforced Roof w/ EPDM Membrane over 3/8" Roof Decking.....Double Wiper Seals on All Slideouts....etc....etc....etc...
    Geez man... compare....!!!!
    bumpy
  • I think with the proper hitch setup the truck will be fine to carry this load. I won't win any races but should be able to haul and stop safely.
    I've read of people wih 1500's hauling more weight thanI listed above. I'll have a brake controller, WD hitch etc.
    If the concern is weigh then the HL is the better choice, correct?
    We're getting a toy hauler with a separate garage, if anyone knows of anything lighter I'd appreciate suggestions.
  • Do yourself a favor. Look on your drivers door specification sticker for payload and axle ratings. That trailer is 6500# empty, probably 8,000# loaded to camp without toys. Add in your family and stuff in truck. Make sure you have enough truck (BTW I would reduce the manufactures ratings by some significant percentage due to the lift kit, like 50%). Not about to try to tell you what to do but this is a significant hint.
  • well the Coachmen has a rubber roof so I wouldn't want it myself.
    bumpy
  • Personnel I would stay away from Coachmen if you plan on keeping the rig for more than just a couple of years. There construction, quality, and material lacks a lot. Look closely at the max weight and the axle weights since a lot of manufactures cut corners here Go over every inch of the roof and side walls since this seems to be an issue with Coachmen!
