D_E_Johnson's avatar
D_E_Johnson
coiled breakaway cable for 5th wheel
Has anyone used the coiled breakaway cable? Our regular cable has gotten stuck under the hitch rail at least 2 times. Its a bugger to get out when you are traveling and it gets damaged. We are going out today to look for the coiled cable.
Need your expertise on this product.
Thanks, Dona
  • Furch5263 wrote:
    On another note here do you guys connect your brake away cables to in the truck bed. I know you are not supposed to connect them to the hitch
    Well, now you got me curious. I throw mine over the hitch handle. Why not?
  • I replaced mine with a coiled cable. Didn't need to change the pin in the switch. It came with a loop that fit the hole in the pin. Good upgrade, no downside that I can see.
    Don't recall where I bought it, but probably just off the shelf at CW.
    Here is one example.
  • I've been looking at one at a dealer here in Colorado. I've also had troubles with cable getting under hitch, however; I now have a B&W puck hitch, and I don't think it will get under. Just haven't figured out where to connect to the B&W hitch yet. I may try the coiled connector.
  • I would to like to know here to get those coiled brake away cables. Seems like i am always buying either the cables or the baggage compartment clips when i go into the RV store. On another note here do you guys connect your brake away cables to in the truck bed. I know you are not supposed to connect them to the hitch. Would like to know what other guys are doing. I have the reese slider 16k.
  • Are all breakaway pins the same? Can I order any coil with a pin attached and expect it to work with my current switch?
  • I bought one but refused to use it. It just doesn't look very sturdy at the connections.
  • The coiled cable is all the dealer had, close to where I was camping when I found the original damaged. I was skeptical, have appreciated how it stays out of the way. Thankfully, haven't needed to 'test' it!
