Last week, I sanitized the fresh water system on my 2011 Keystone Montana 3400RL 5th Wheel. Now this cold snap will bring temps down to 25 degrees tonight. I used the Thetford system to sanitize ...
I think that the confusion is about draining. The water tank is not affected by draining the low water drains. It has its own drain which is not opened in this case. The low water drains are located under the bottom of the trailer. They are two lines, one blue,cold and one red,hot. Only the water lines are affected by these drains.
