memtb
Mar 31, 2019Explorer
Just my opinion here,if you have forced air heat to your basement ( tanks, plumbing, ect.) area....you should be fine! Likely the lows in the mid 20’s will only be a small % of the 24 hour period! The RV should be like “heat sink”, absorbing the warm daytime highs, and slowly lose temperatures as the ambient temperatures lower. “IF” a water line is exposed or running in contact with frame directly exposed to ambient temps.....All bets are off!
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
