way2roll
Feb 24, 2022Trailblazer
If you have been having sustained temps in the low 20's F, then it may already be too late. It takes one gallon of water 4 hours to freeze at 32 degrees and expands 9%. Have you already drained the rest of the system? Pipes, pumps, strainers, unions and fixtures will crack first.
If your plan is to fire it up, I would wait around a while to look for leaks. You may end up thawing it, revealing a leak and subsequently heating air if left alone.
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
