- My answer to customers has always been----If it is below 32 degrees, take precautions and drain. There is NO WAY anybody can give a definite answer to your question about how low and how long freezing temps before damage happens. IF you have the Water Heater in use(LP or 120), then I would not worry. That is 140 degree water. But, as I also tell customers, if in storage, what happens if the Power goes out or your LP system malfunctions. Doug
- wildtoadExplorer IIIf you’re not using your wh drain it. Perhaps your manual says just that.
- Any predicted temp at or below 35 and I drain it unless, of course, I am using it.
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 27, 2025
