MFL
Jan 30, 2016Nomad II
CloudDriver wrote:
The thermostat sensor for the refrigerator is in the refrigerator section, not in the freezer section.
If the RV heating system isn't running to keep the inside of the the RV warm, the refrigerator section will stay cool due to the low winter temperature inside the RV and the thermostat won't turn the cooling unit on very often, if at all.
Try turning the heat on to warm up the inside of the RV, which will then warm up the inside of the refrigerator section, which will cause the thermostat to turn on the cooling unit, which will bring down the temperature in the freezer.
Good post. Yes OP, you need to have some heat going inside the coach, for best fridge operation.
Jerry
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
