vcv
Jan 08, 2021Explorer
cummins2014 wrote:vcv wrote:
Okay folks, here are the results. The raw data is within the image file, and I have consolidated the data below:
Ford: Total of 40
(6.7's dominated the Ford category, no surprise. It was good to see some 6.0's out there, bullet proofed I'm sure. I did not identify a single 7.3, but I know they are still out there!)
Ram/Dodge: Total of 34
(Obviously 6.7's dominated. Most of the 5.9's I identified looked to be well kept and towing older 5rs)
Chev Duramax: Total of 25
(Most all of the Dmax were late model rigs, mostly single axle. I identified 4 LBZs. I have an affinity for the LBZ's, even though I have never owned one)
Topkick/Freightliner: Total of 3
(2 Freightliners and 1 Topkick)
1/2 Ton's towing 5th Wheel: Total of 4
(I changed my data collection on this one to reflect any 1/2 ton towing a 5th wheel, rather than what I feel is "overloaded". There are a few folks on here who seem to be hypersensitive to the issue, so I'll keep that data and opinion to myself.
Of the 1/2 tons I saw, two were Ford and two were GM, all late model. One was at a love travel stop fueling up, one was in a campground, and the other 2 were on the road)
Are these trucks in passing ,going the other way , how do you tell the difference from an early 6.0 to 7.3. I have learned that the only way to tell some of the earlier 7.3 Suoerduties to the later 7.3 is the badge on the front fender, the early ones were in the front of the fender the later were lower rear part of the fender, as were the 6.0 Also got to be be quick in passing to be able to tell the early 99 Superduty 7.3 from the V10, nearly the same badge on the front of the front fender. Just curious
Data collection is not perfect. To your point, it is very hard to tell the difference in a 2003 year model if it is a 6.0 vs 7.3. if I cannot get a good look it. But then I'm not logging that data. I also could have mistaken a Ford gasser from diesel (not many guys tow heavy 5rs with a gasser). Overall the data is accurate. I know trucks, I know the models, I know the engines, the badges, the grills, etc..
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
