klawklr650
Nov 27, 2013Explorer
Condensation and Roof Construction Concerns
Hi folks. I'm seeking info from you guys who've been doing this a while. This is my second winter in our FW as a camp host in northern Louisiana. I don't remember seeing any condesation last winter but I'm sure I had some because I have it now. I understand, from reading in the forum, that it is a normal occurance on the windows and might even be somewhat helpful according to some. I'll have to keep an eye on the windows to see how this developes. My concern is actually in the bathroom. I see the shower skylight (exterior bubble) has condensation on it (shower is not used). I've removed the interior trim panel to wipe things down. I noticed the wood framework forming the roof structure is open on two of the four sides. I would have thought it should be sealed to prevent moisture from seeking it's way into the roof area. I know houses need a sealed (cold) roof to prevent interior sweating. So, I taped the open sides of the framework with duct tape. Was this a good move or am I too smart for my own good? Also, should the trim panels have any sort of sealing product such as putty tape to help keep the heat or moisture from sneaking its way into the roof area?
Just to provide a little more insight, I do use two electric heaters. One in the living room and one in the bathroom. We use an electric heating pad on our select comfort mattress. We also use the propane heater set on 63-65 degrees. Thoughts?
