RVhiker
Nov 17, 2017Explorer
Like this valve: http://www.campingworld.com/shopping/item/twist-on-valve/27868. It fastens on to a common outlet connection for the grey tanks. CLOSE the twist on valve. OPEN the grey tank valves. Grey tank fluid seeks a common level and fluid flows from the fuller grey tank to the emptier one (if both tanks are at the same elevation).
When you dump with this in operation, connect to the twist on valve.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
