We purchased the Jayco rig in our signature used, a couple of years back. Our second fiver and the first with electric slides as our prior rig was a Cedar Creek with hydraulic slides. Our Jayco has three slides, with one being a heavy one holding the fridge, pantry, kitchen, etc. We did experience a problem when the motor brake on the on the large slide gave out, allowing the slide to creep out an inch or two when traveling. Fixed that and no problems since. The only thing I don't care for is the amount of time it takes to put the slides out. Seem to run much slower than our prior hydraulic system, but that's a nit. And I don't particularly like the way they designed the plumbing for the fresh water tank. Our old rig had a hose bib, while this one fills the tank via the 'utility center', where the water has to go through some fairly small pipes to make it to the tank. It works, but it takes a long time to load up with 80 gallons of fresh water.Again, not a killer issue, but something that is inconvenient. Overall, we've been very pleased with the quality of the build, cabinetry, and design, and plan on having this rig for a good long time go come.
