sdetweil
Jun 15, 2016Explorer
RustyJC wrote:
I use the TST507 system with flow-through sensors on both the truck and 5th wheel. Our 5th wheel, perhaps due to a combination of length and placement of the display unit low on the console, does require the repeater to get reliable signals from the 5th wheel's tires.
While some may prefer the non-flow-through sensors, if I were to use them, I'd have to dismount the outer dually tires to add air to the inner dually tires.
Rusty
I used braided extensions to surface my dually stems out by the center cap
I use the non-flow thru on the dually. as the flow thrus wont fit on the front tires. I pulled the security covers from the non-flow thru sensors as well to be able to mount them on the front wheels. (2012 Ford F350)
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
