BB_TX
Jun 15, 2016Nomad
TST here also for 5 yrs. Most of the time, it receives signals with no problem. But on occasion it will take a while to pick up a sensor(s), or lose a sensor(s) temporarily while driving. The only way to tell is that the pressures and temps remain static for long periods. Recently after a short time on the road I had one sensor showing much higher temp and pressure than other 3. First thought was tire problem. Stopped and checked. Soon realized that sensor was the ONLY one actually monitoring properly. Others started some time later.
35' 5er with crew cab long bed truck. And I mount it low on the windshield so that the monitor sits just barely above the dash. That may be the problem. Just bought a repeater to try to eliminate that issue.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
