jwakemanExplorerApr 10, 2017Converter / Inverter relationshipCame home from Texas and parked by the house, Went to check on things a week later and found the inverter had tripped the fuse between the inverter and Positive on battery and the control panel displa...Show More
time2rollNomadApr 10, 2017The battery level meter is just a voltmeter and most likely gets the reading from the 12 volt distribution panel.
Related ContentInverter Bad?Inverter installInverter/ConverterInverter/ConverterNo 12 Volt without converter
